So I been reading around and apparently with
AUDACITY's
Analyze , Plot Specturm , Freq Analysis
You can generally get EQ Settings used on a PRO RECORDINGS ?
So I could stick in an AUDIO WAVE OF Nirvana Smells Like Teen Spirit and kind of see what
Andy Wallace and Butch Vig Did ?
Also found this topic on another board , check it out ?
http://www.bootlegzone.com/phpBB3/viewt ... 47&start=0
MATCH EQ With AUDACITY
pennyroyaltea94
Re: MATCH EQ With AUDACITY
Steve did make an experimental plugin to do that ... http://forum.audacityteam.org/viewtopic ... 37#p203837
[Further reading ... http://forum.audacityteam.org/viewtopic ... 53#p258053 ]
This only works well if you know what the original was. A certain tonal boost is going to have very different effects between a Glen Glenn sound recording and me in the back yard. That and not all corrections show up in the equalization. Echo and phase corrections don't necessarily cause volume changes.
