Bug: Project Rate entry not handling keystrokes properly
fas42
Post by fas42 » Sun Oct 01, 2017 6:43 am
Windows 8.1, in both 2.1.2 and 2.1.3 versions, direct numeric entry misbehaving: the keystroke 1 not registering, 2 to 0 OK, backspace being sent to the selected track. By trial and error found the numeric keypad did work correctly.
In version 2.1.1 this did function as expected.
Re: Bug: Project Rate entry not handling keystrokes properly
Post by kozikowski » Wed Oct 04, 2017 3:09 am
It does that on Mac version, Audacity 2.1.3, too.
Post by steve » Wed Oct 04, 2017 9:06 am
It's been fixed for the up and coming 2.2.0 release.
