Audacity stil doesn't start
Please state:
bass_man
Post by bass_man » Fri Sep 29, 2017 10:05 am
Hi Steve,
hi everybody,
I read other posts, other topics, but I didn't find my problem and the right answer for it.
I'm under Ubuntu 16.04 32 bits, with GCC (Ubuntu 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609 version
and I wanted to install (compiling) Audacity 2.1.3, following your post viewtopic.php?f=19&t=88943 with the special line in red.
All is compiled and installed well. But when I want to start Audacity, here is what I obtain :
error message in terminal
My question is simple : what can I do to resolve this problem ?
Is it a GCC version problem ?... (5.4 instead of 4.9) - The actual GCC version is 7.2.0, but I didn't install it.
Thank you for your help, I hope...
Re: Audacity stil doesn't start
Post by steve » Fri Sep 29, 2017 12:34 pm
bass_man wrote:I'm under Ubuntu 16.04 32 bits, with GCC (Ubuntu 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609 version
Those instructions are for building Audacity 2.1.2 on Ubuntu 14.04 (LTS).
Ubuntu 16.04 has an appropriate version of gcc by default, so those "special" lines in red are not appropriate.
It looks like you have the wrong version of wxWidgets installed.
You need libwxgtk3.0-dev
bass_man
Post by bass_man » Fri Sep 29, 2017 1:12 pm
Well, I've installed wxWidgets 3.0.3 version. I read somewhere that it's the right version for Audacity...
But I saw in Synaptic that libwxgtk3.0-dev wasn't installed. So, I installed it.
Now, for GCC, should version 5.4.0 be OK for Audacity 2.1.3 ? or not at all ?...
For now, I'm going to uninstall Audacity installed as you told me in an other post, restart and install again. I will tell you...
Post by steve » Fri Sep 29, 2017 1:38 pm
I'm using:
gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.4)
You can have several versions of gcc installed at the same time. To get the version number of the currently configured version, enter this in a terminal window:
Code: Select all
gcc -v
bass_man
Post by bass_man » Sat Sep 30, 2017 6:49 am
The gcc version used is 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.4)
Should I install the latest one ? (7.02)
How to set a version (gcc, or wxWidget, or everything else...) in LD_LIBRARY_PATH, OR PKG_CONFIG_PATH ?...
(I don't know if it is the right method...)
After having installed libwxgtk3.0-dev, uninstalled Audacity, restart, an installed again, it is the same problem :
I don't understand what I should have missed... :?
Any idea everybody ?... :roll:
