Sent Project with AUP file and .AU files not opening
cameronsnicholls81
- Operating System: macOS 10.14 Mojave
Re: Sent Project with AUP file and .AU files not opening
Ok, thanks Koz, much appreciated
Post back if you get something to work. This is a common problem.
