Need Help Recording System Sounds using Windows WASAPI
chichun2002
Post by chichun2002 » Sun Sep 24, 2017 7:27 am
I'm trying to record system sounds using Windows WASAPI but no matter what speaker device I use to record it keep popping up with this error "error opening sound device try changing the audio host recording device and the project sample rate" I've already tried a lot of tutorials to try and fix this issue but nothing seems to work please help :(
groundnoiseindustrie
Operating System: Windows 7
Re: Need Help Recording System Sounds using Windows WASAPI
Post by groundnoiseindustrie » Mon Sep 25, 2017 8:26 pm
Maybe you can post some screen shots of your settings in windows and audacity. I usually find it is one check box somewhere causing the problem.
