two micrphone recording
felixthecat535
Post by felixthecat535 » Thu Oct 11, 2007 1:00 pm
Help please
need to plug two usb microphones into audacity to do podcasts can this be done
thanks
Jemax
Re: two micrphone recording
Post by Jemax » Fri Oct 12, 2007 12:01 pm
felixthecat535 wrote:Help please
thanks
i believe it depends from your sound card and its interface. By itself Audacity can't manage separatly 2 micrphones.
Bon à savoir : soyez chics, si votre problème a trouvé solution, inscrivez "Résolu" dans le titre de votre post INITIAL.
Merci du suivi.
Post by kozikowski » Wed Oct 17, 2007 10:02 am
Audacity will accept up up 16 audio channels from any one audio device. It will not accept more than one device, so no, you can select either of the USB microphones, not both.
You should be able to do this whether or not you have a sound card in your machine. The sound card counts as one device.
Lots of people make simple analog audio mixers that connect to the computer with USB, but I don't know of a USB mixer. It's possible. People are still shy of digital audio stuff because of delay and latency issues. If you listen to yourself in headphones, you can get a delay between your speech and the sound. Drives most people nuts.
