Some problems with launching audacity.
юра00
Post by юра00 » Tue Sep 19, 2017 9:13 am
The program is launched only if Microsoft Visual C ++ 2013 is installed for 32 bits. Otherwise it doesn't start. That is, the program requires additional installation vcredist_x86. I can't download, it is more than 4 MB. But when I delete it, the program stops running, gives an error message, "no dll is found". Please, check and correct.
audacity-win-e984211-2.2.0-alpha-21aug17.
юра00
Re: Some problems with launching audacity.
Post by юра00 » Tue Sep 19, 2017 11:19 am
Error message:
юра00
Post by юра00 » Fri Sep 22, 2017 7:26 am
My translation of the error message:
Code: Select all
The code could not be continued because the system did not detect MSVCR120.dll. To fix this problem, try reinstalling the program.
юра00
Post by юра00 » Sun Sep 24, 2017 1:27 pm
Specially asked other users to download and run the program from another computer. They have the same error message.
юра00
Post by юра00 » Sun Nov 05, 2017 4:20 pm
However, for release version Audacity 2.2.0 the error is fixed. Thank you very much!
