No Sound on Win 10
Altenfurtz
No Sound on Win 10
Post by Altenfurtz » Thu Sep 14, 2017 1:21 am
I am using Win 10 and have downloaded Audacity twice and there is no sound. My pc is a Lenovo Thinkcenter. After much work, I think I have removed Audacity. I tried soundtrap and it will record so I think the audio is OK.
Used Audacity on Win 95 with no problems and display looks same. Anyone know how to get the streaming audio to record? I really liked Audacity.
Re: No Sound on Win 10
Post by kozikowski » Sun Sep 17, 2017 12:36 am
http://manual.audacityteam.org/man/tuto ... puter.html
The hard part is not recording in Audacity. The hard part is recording streaming audio. That gets harder each Windows version.
Also see: Voicemeeter.
http://www.vb-audio.com/Voicemeeter/banana.htm
