hi
can u manuelly edit a song as you put it into your computer from a turntable or cassette deck?do i need more additions to the
software to do this?whats the procedure do put tunes into the computer?thanks.
coonsanders
a question
coonsanders
Re: a question
<<<u manuelly edit a song as you put it into your computer from a turntable or cassette deck?>>>
No. Audacity doesn't do anything in real time except record and play back. The closest thing to editing you can do is press Pause during a recording.
If you press Stop, Audacity will start a new timeline and not add to the existing recording like Pause will.
coonsanders
Re: a question
hi koz
i c but after you put the song into the computer with audicity you CAN edit the song right?your just putting in the song at this
point just to save it.then after u save it title it THAN you can edit it right?thanks
coonsanders
coonsanders
Re: a question
After you get your song into Audacity, then you can edit your brains out. Audacity is a Post Production editing tool.
After all the actors and singers go home, you sit in a dark room with Audacity and make the actual finished song out of the pieces they did.
When you see pictures of a movie camera, the thing on top holds the movie film. It usually holds 1000 feet which works out to 11 minutes. Then they have to change film. That two hour long movie you sat through last week at the CinePlex was made up of 11 minute chunks stuck together in a dark room by an editor.
Audacity is the sound version of that.
