Different background colors for numbers in drop down boxes
scootergrisen
Operating System: Windows 7
Post by scootergrisen » Tue Sep 05, 2017 12:14 pm
Windows 7 64-bit - Audacity 2.2.0-beta-Sep 1 2017 - .exe-installer
Using Windows 7 classic theme.
I dont like how the background color under each digit is slightly lighter then the rest of the background.
Also the dropdown arrow background is using the same background color which does not look so good.
