Preferences Spectrograms page looks different
scootergrisen
Operating System: Windows 7
Post by scootergrisen » Mon Sep 04, 2017 8:16 pm
Windows 7 64-bit - Audacity 2.2.0-beta-Sep 1 2017 - .exe-installer
For some reason the Spectrograms page looks different in 2.2.2 beta. Like its indented and slightly diffent backgroun color. In 2.1.3 it looked like the other pages.
Re: Preferences Spectrograms page looks different
Post by steve » Mon Sep 04, 2017 8:27 pm
scootergrisen wrote:For some reason the Spectrograms page looks different
It's because the Spectrograms page was converted quite late in the day from an 'normal' page to a scrolling page. This will probably be changed in the near future, but was intended as a quick fix for the problem that the controls at the bottom of that page were not visible on some systems.
On my computer I can just see a subtle difference in colour, but I see the difference is much greater on your computer.
I'll add a note about this on the bug tracker.
scootergrisen
Post by scootergrisen » Mon Sep 04, 2017 9:35 pm
I use the classic Windows theme and thats properly why i see a greater difference then with the default Windows theme.
