Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
scootergrisen
- Operating System: Windows 7
Post
by scootergrisen » Mon Sep 04, 2017 7:04 pm
Windows 7 64-bit - Audacity 2.2.0-beta-Sep 1 2017 - .exe-installer
For some reason i can use Alt+l to open a menu.
If i hold shift at the same time it opens.
Code: Select all
#. i18n-hint: Ext-Bar is a menu with extra commands from tool bars
#: src/Menus.cpp:1265
msgid "Ext-&Bar"
msgstr "Ekstra&linje"
