Colors and logo in about dialog
scootergrisen
Operating System: Windows 7
Post by scootergrisen » Mon Sep 04, 2017 6:40 pm
Windows 7 64-bit - Audacity 2.2.0-beta-Sep 1 2017 - .exe-installer
The white background color does not look good in Windows using classic theme.
I would prefer just to default baggrunds color.
Like the preferences dialog and guess ever dialog expect the about dialog.
Not the missing white in the bottom right corner, and the border and the bottom of each tab that is not active.
Also the logo seems to be streatched.
Compare with.
Would be better to use a transparent logo so the background color would work with the logo no matter what color it is.
scootergrisen
Re: Colors and logo in about dialog
Post by scootergrisen » Wed Sep 06, 2017 11:21 pm
The welcome dialog have the same problem with the background color.
Part of the resize square is below the OK button.
waxcylinder
Post by waxcylinder » Thu Sep 07, 2017 1:35 pm
Looks like that - and looks fine to me in both Classic and Light theme.
And the dark variant in Dark and High Contrast themes also look fine to me
W10 Beta 02Sep17
Peter
scootergrisen
Post by scootergrisen » Thu Sep 07, 2017 3:28 pm
Can you show pictures with Windows classic theme that you think looks fine.
waxcylinder
Post by waxcylinder » Thu Sep 07, 2017 4:48 pm
Welcome mat - Light theme.png (36.37 KiB) Viewed 727 times
Welcome mat
waxcylinder
Post by waxcylinder » Thu Sep 07, 2017 4:49 pm
About Audacity - Light theme.png (38.97 KiB) Viewed 727 times
