I am using Audacity 2.1.3 in Windows 7.
I have a language learning CD which has pauses for repetition but the pauses are not long enough for a normal person to repeat what was just said for language learning / practice.
Does Audacity have any feature that allows one to increase automatically any period of silence by a fixed amount in a track?
Say increase a silence of 2 seconds to maybe 6 or 8 seconds.
Thank you.
Increasing sections of silence in a track
multilingual
- Operating System: Windows 7
Re: Increasing sections of silence in a track
There's a plug-in here that may help: viewtopic.php?p=247774#p247774
For installation instructions, see: http://wiki.audacityteam.org/wiki/Downl ... ns#install
multilingual
Thank you - looks exactly what I was looking for.
