Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Gideon
Post
by Gideon » Mon Aug 14, 2017 10:44 am
I lost an old audacity file and needed to edit the MP3 file, so I obtained an app called
'MP3DirectCut'. Its not as comprehensive as Audacity but quite smart for doing jobs like this. A problem arose however, when I tried to hook up
'Lame.' It couldn't be found?
Has anyone here had any experience with this problem?
I extracted MP3DirectCut on to my desktop then copied the folder to Windows > Program Files. It worked fine, but when it came to recording, it asked for Lame. So I placed lame_enc.dll in the same folder with no luck.
Any clues?
DVDdoug
- Forum Crew
Post
by DVDdoug » Mon Aug 14, 2017 2:46 pm
I'm surprised mp3directCut doesn't have their own forum... but anyway...
Are you getting any error messages? Is it still asking for LAME? Did you go to Settings -> Configure -> Encoder and select LAME?
Of course, if you're recording you can record in Audacity and export to MP3.
