There is a "Harmonic Noise" plugin for Audacity, where you can select how may harmonics you want, and exclude the even ones ... http://wiki.audacityteam.org/wiki/Nyqui ... onic_Noisejamesadrian wrote: There are, of course, many short-cut features that could be on the menu. A clarinet has only odd numbered partials. Clicking off or attenuating even numbered partials should not require a lot of up and down drawing.
Synchronizing multiple mp3 files
Re: Synchronizing multiple mp3 files
jamesadrian
As part of my project, I am looking for a program that will accept eight wav files as input and produce a multi-channel output. I have had no luck. Does Audacity have such a function?
Thank you for your help.
Jim Adrian
Jim Adrian
Audacity can produce multi-channel audio files from multiple tracks. See: http://manual.audacityteam.org/man/adva ... tions.html
jamesadrian
Steve,
Thank you for this valuable reply and link. I appreciate it.
Jim Adrian
Jim Adrian
