Hello eveybody,
I have just compiled Audacity from source without errors on my PC.
Now i'm trying to compile it on my laptop (UBNUTU 16.04). When i launch the make, I receive this error:
audacity-AudioIO.o: In function `AudioIO::MidiTime()':
/usr/local/audacity/src/AudioIO.cpp:4001: undefined reference to `PaUtil_GetTime'
collect2: error: ld returned 1 exit status
Makefile:2350: recipe for target 'audacity' failed
make[2]: *** [audacity] Error 1
make[2]: Leaving directory '/usr/local/audacity/src'
Makefile:1588: recipe for target 'all' failed
make[1]: *** [all] Error 2
make[1]: Leaving directory '/usr/local/audacity/src'
Makefile:799: recipe for target 'all-recursive' failed
make: *** [all-recursive] Error 1
BUILD FAILED (exit value 2, total time: 34m 51s)
Can you help me please ?
This the installation steps i adopted to compile from source:
System Settings -> Software and Updates -> Enable Source Code -> Close -> Reload.
Open a terminal (press Ctrl + Alt + T)
sudo apt build-dep audacity
sudo apt install git
git clone https://github.com/audacity/audacity
cd audacity
./configure
make
sudo make install
audacity
Thanks in advance.
Vincenzo.
make error
Please state:
Please state:
Re: make error
Code: Select all
make distcleanThen run configure again, adding
Code: Select all
--with-portaudio=localFor example, for a debug build that will work with ffmpeg
Code: Select all
../configure CXXFLAGS="-std=gnu++11" --disable-dynamic-loading --with-portaudio=local --enable-debug9/10 questions are answered in the FREQUENTLY ASKED QUESTIONS (FAQ)
