When I start to record the timeline doesn't move and it says TIMELINE ACTIONS DISABLED DURING RECORDING.
I have looked at settings and can't work out how to get rid off this. I'm using 2.1.3 on Windows 10.
Many thanks
That is unrelated to the problem of it not recording. See my first reply in this topic for an explanation of what this message means: viewtopic.php?p=329970#p329970
I assume that you mean that Audacity goes into recording mode, but the cursor does not start moving (stuck at the start of the track).
Yes, that's the next thing I was going to suggest (your post arrived just as I was postingMrDay wrote: ↑Sat Oct 03, 2020 8:42 amHello, thanks for this Help facility, on searching further I seem to have found the solution, which was to set the rate in Audacity to 48000, which now matches that elsewhere in the PC (Windows) setup for the Mic and playback...
From Re: unable to listen to track while recording by steve » Thu Sep 10, 2020 12:32 pm
"There are three "sample rate" settings that should all be the same:
In the Recording tab of the Windows Sound control panel
In the Playback tab of the Windows Sound control panel
Audacity's "Project Rate" ... "
