First track ok, 2nd track is 1 octave lower on new Windows10
pisig
Re: First track ok, 2nd track is 1 octave lower on new Windo
Post by pisig » Sun Jul 30, 2017 7:36 pm
steve wrote:
pisig wrote:first track seems to be okay, but the 2nd, 3rd and so forth tracks are 1 note (or 1 octave?) lower
You seems to be uncertain whether it is "1 octave". Why is that?
I figured it out that it is just a half-step lower, not 1 octave lower. So my instrument is standard tuned, then the recording was Eb. Also noticed some split-second skip beats.
pisig
Post by pisig » Sun Jul 30, 2017 7:39 pm
By the way, aside from the track being recorded 1 half-step (not 1 octave as I have figured it out) lower, there also noticeable skip beats and tempo changes after every couple of seconds or so.. Track playback seems to momentarily slows down then fasten up...
Post by steve » Mon Jul 31, 2017 8:27 am
The bug described in #23 here may be relevant: http://line6.com/support/topic/16083-he ... /?p=119249
Post by steve » Mon Jul 31, 2017 8:42 am
Try setting the default sample rate in Audacity to 48000 Hz (in "Edit menu > Preferences > Quality")
Also set the device to 48000 Hz in the Windows Sound Control Panel.
Then close and restart Audacity, and make a test recording.
