Hi,
I have had to install a new hard drive and now when I try to download Audacity I cannot succeed! Please advise how to download Audacity. I have used Audacity for years and I have recording gigs to do.
thanks and kind regards
Mike Crouch
downloading Audacity
Mike Crouch
Mike Crouch
Re: downloading Audacity
I have a Lenovo L530 laptop with Windows 8.1Pro. I would like to download the latest issue of sofrware
regards
Mike Crouch
regards
Mike Crouch
Official Audacity download for Windows is here ...
http://www.audacityteam.org/download/windows/
