Manipulating Audio Files
Trebor
Re: Manipulating Audio Files
Post by Trebor » Sun Jul 02, 2017 8:56 am
erinpeterson wrote:... I've followed the steps you suggested, but when I tried actually using the envelope follower nothing happened. I highlighted both tracks, went to the effects menu, clicked the envelope follower, and confirmed it...
Select two tracks, (one to be followed is the upper one).
Then choose envelope-follower from the effect-menu, then press "OK" ...
Enverlope-Follower plugin dialogue (press OK).png (12.93 KiB) Viewed 219 times
[/url]
If nothing happens maybe you need to upgrade to the latest version of Audacity.
( I can testify that envelope-follower plugin works in Audacity 2.1.3 )
