Error Opening Project...
chall1216
Post by chall1216 » Wed Jun 28, 2017 5:59 am
Hi all,
I am using Audacity 2.1.1 on Windows 10. I tried to open a my project (weeks of work... ) and received this message:
"Error Opening Project. Error Reference to Invalid Character number at Line 14827."
A bit concerned I just lost a lot of work. Next time I will save a back up AUP file in another location....
Any advice out there? I've attached the file... Thank You.
Best,
Chris
Part 1 - Carnival.aup
(757.58 KiB) Downloaded 8 times
Re: Error Opening Project...
Post by Gale Andrews » Wed Jun 28, 2017 11:52 am
The current Audacity version is 2.1.3 http://www.audacityteam.org/download/windows.
Audacity on Windows doesn't support emoji in track names or metadata. I removed the problem from both channels of the "Night Train" track, so try it now (attached).
(757.55 KiB) Downloaded 10 times
chall1216
Post by chall1216 » Wed Jun 28, 2017 12:34 pm
Thank you very much!
The project opens again.
Also, happy to work with Audacity 2.1.3. Looks like a distortion effect was put in.
Best,
Chris
