Recording from stereo LP but tracks identical [SOLVED]
Windows 10 - Audacity 2.1.3: I recently untangled driver problems, but I continue to see only two identical tracks when digitizing from stereo LP. MME set, rate at 44100, playthrough set and working fine. 2 stereo set. USB mic works well, speakers work also. I can hear the second track playing but only see identical wave forms on top and bottom of the screen ... help!
- Quality Assurance
Re: Recording from stereo LP but digital tracks are identica
You have to change Windows to record in stereo too. See this FAQ: http://manual.audacityteam.org/man/faq_ ... #rinstereo.
Re: Recording from stereo LP but tracks identical [SOLVED]
Perfect! Yes, I had missed that setting, thanks.
