export multiple problem
jmmiller1943
I'm using Mac OS Sierra 10.12.5, and Audacity 2.1.2 .dmg. I've used Audacity successfully on my Mac to convert vinyl records to WAVs, but my most recent project returned this error message at the end when I attempted "export multiple": "Cannot export audio to /Users/John/Music/The Great Music Themes of Television/Great Music Themes WAVs/1 The Coca-Cola Company Theme/Eddie Fisher Show.wav." That was the first track in the project. Its label was at the very beginning of the .aup file, and the next message was that 0 files were exported. Can you help me? Thanks, John
- Quality Assurance
Re: export multiple problem
If the label itself contains a forward slash, remove the slash. This is fixed in the current 2.1.3 release: http://www.audacityteam.org/download/mac.
