Window Problem in Export 2.1.3 [SOLVED]
Help for Audacity on macOS.
getstew
Post by getstew » Mon Jun 19, 2017 4:57 am
Version 2.1.3. Mac. El Capitan. The text in window is cutting off when exporting MP3 (see below).
Any fix for this? Thanks!
Screen Shot 2017-06-18 at 9.41.29 PM.png (731.69 KiB) Viewed 456 times
Last edited by Gale Andrews on Tue Jun 20, 2017 12:07 pm, edited 2 times in total.
Reason: placed image inline so that it fits Forum layout
Re: Window Problem in Export 2.1.3
Post by Gale Andrews » Mon Jun 19, 2017 11:22 am
getstew wrote:Version 2.1.3. Mac. El Capitan. The text in window is cutting off when exporting MP3 (see below).
Any fix for this?
You apparently don't know that on modern Mac, file save dialogues open by default in collapsed state.
Try clicking the downward-pointing arrow on the right of the Save As: box to expand the dialogue.
To force Mac to always open dialogues expanded, see https://www.tekrevue.com/tip/expanded-save-dialog-os-x/.
getstew
Re: Window Problem in Export 2.1.3 [SOLVED]
Post by getstew » Mon Jun 19, 2017 5:13 pm
Huh... That was it. I've owned a Mac 4+ years and have never had that come up. Thanks.
