download LAME dll
fpefpe
download LAME dll
Post by fpefpe » Thu Jun 15, 2017 8:25 pm
Hello -- I tried to export my project to a mp3 file, but there was no lame.dll in the path -- the popup noted that I would download the
dll at that point -- I when to FLAC in stead .... what is the URL to get the LAME.dll doenload? Thanks
Re: download LAME dll
Post by steve » Thu Jun 15, 2017 8:30 pm
See here: http://manual.audacityteam.org/man/inst ... ml#winlame
Downloading the EXE version is usually the best option as this will install LAME in a location where Audacity can find it automatically.
