AudioBook Mastering version 4
Post by kozikowski » Sun Jun 11, 2017 9:53 pm
AudioBook Technical Mastering
(revision 1, minor corrections 2017-12-08)
(revision 2, New and Improved RMS Normalize 2018-07-25)
(revision 3, Bold for clarity 2018-08-25)
— PURPOSE:
This is a suite of Audacity tools and process to help you produce an audiobook reading that reaches ACX Technical Compliance. See NOTES AND COMMENTS at the end.
— CUSTOM TOOLS:
We designed custom AudioBook Mastering tools. You have to install them.
Get and install ACX-Check
http://forum.audacityteam.org/viewtopic ... 02#p310702
Get and install RMS-Normalize
viewtopic.php?p=325078#p325078
— SETUP:
Use Audacity version 2.1.3 or later. Not optional.
http://www.audacityteam.org/
Start this process with a raw, uncorrected reading. No processing, adjustments or fixes. Don't help.
Export a WAV (Microsoft) 16-bit sound file of your raw reading and save it in a safe place. You should never be stuck reading a chapter again because of an accident. Saving an Audacity Project is not recommended for this.
— PROCESS:
These instructions are in short-form: Location > Tool: Options > OK
Select the whole reading or chapter by clicking just right of the up arrow button (on the left).
Effect > Equalization > Select Curve: Low rolloff for speech, Length of Filter: about 5000 > OK.
Effect > RMS Normalize: Target RMS Level -20dB > OK.
Effect > Limiter: Soft Limit, 0, 0, -3.5dB, 10, No > OK.
Analyze > ACX-Check.
The first two readings, Peak (no louder than -3dB) and RMS (between -18dB and -23dB) should be nearly perfect. If the noise is quieter than about -65dB (-60dB limit), and the show sounds reasonable, you may be done.
If you fail noise, then the process can be a great deal more interesting. See Noise Posting, below.
— NOTES AND COMMENTS:
ACX has their own help pages, tutorials and videos.
http://audible-acx.custhelp.com/
This mastering suite addresses technical considerations. Nothing here will address theatrical errors such as harsh sibilance, gritty voice or wet mouth noises. There is no acting filter. You have to know how to read aloud.
The quality of the original recording is very important. It's easy to record mistakes that can't be fixed later. Record to a reasonable volume (occasional peaks at -6dB) in a quiet room with no echoes.
When you get done with a chapter, File > Export the work as WAV (Microsoft, 16-bit) and save the sound file with a unique name somewhere safe. That's your emergency backup so you don't have to read it again if you damage the work or lose your edit.
Only then start editing, processing, filtering and correcting. Keep testing the work with the add-on ACX Check analysis tool as you go. Select the work and Analyze > ACX Check.
ACX Technical limits:
— Peaks no louder than -3dB.
— RMS (performance loudness) between -18dB and -23dB.
— Noise no louder than -60dB.
Those are the top three values in the ACX Check panel
ACX Values in English
http://forum.audacityteam.org/viewtopic ... 23#p297423
Human Quality Control at ACX (the theatrical test after you pass ACX-Check technical test) does not like heavy processing. You should be as gentle as you can with as few corrections as possible. Don't even think of submitting readings that sound like a bad cellphone, speaking into a wineglass or reading in a bathroom.
The AudioBook metaphor is listening to someone telling you a story over cups of tea. Anything that distracts from that ideal should be avoided.
Re: AudioBook Mastering version 4
Post by kozikowski » Sun Jun 11, 2017 11:11 pm
Noise Compliance -- (revision 1, minor updates 20171208)
We assume you've already been through AudioBook Mastering and failed ACX Technical Compliance because of noise (louder than -60dB) or your performance has odd background sounds you don't like. Noise is common in a home studio.
— MICROPHONE HISS:
http://kozco.com/tech/audacity/clips/No ... ophone.mp3
This is a gentle spring rain in the trees ffffffffff sound behind your voice. Microphone systems make noises like this naturally and it's your job to make your voice loud enough so nobody notices the noise, but not so loud your voice distorts.
If the hiss isn't too bad, try a gentle correction such as Noise Reduction of the Beast (6, 6, 6) or UNDO and try 9, 6, 6. You can hear the hiss getting quieter and recede into the background as you increase the first number: Nose Reduction. Try ACX-Check. If you need reduction as high as 12, 6, 6, your voice may get wine-glassy or honky and the show may not pass ACX human inspection.
http://manual.audacityteam.org/man/noise_reduction.html
The solution may be to change your announcing style or even the microphone. You should be about a shaka away from the microphone...
... or as close as a fist (louder and more intimate) but you may need a pop and blast filter.
— MACHINE NOISE:
Computer fan, air conditioning, refrigerators or other machines.
Turn off fans or machines while you're presenting if you can. And yes, we understand the contradiction of needing to watch the Audacity screen, remove the noisy computer from your room and keep the computer one USB cable away from your USB microphone all at the same time. ACX did it by having an almost completely silent laptop in the studio to do the recording.
People have done it by extending the keyboard, mouse and monitor outside their studio, but you are warned against extending a USB cable, particularly with audio (or video) production.
Do not block computer vent holes.
If machine noises are constant and not seriously loud, they may respond to Effect > Noise Reduction.
Try a gentle correction such as Noise Reduction of the Beast (6, 6, 6) or UNDO and try 9, 6, 6. You can hear the hiss getting quieter and recede into the background as you increase the first number: Nose Reduction. Try ACX-Check. If you need reduction as high as 12, 6, 6, your voice may get wine-glassy or honky and the show may not pass ACX inspection.
— MOSQUITO WHINE:
Some computers and USB microphones hate each other and produce mosquito whine sound.
http://kozco.com/tech/audacity/clips/US ... neClip.mp3
Whine doesn't respond well to Effect > Noise Reduction.
Get and install Mosquito-Killer4.
http://forum.audacityteam.org/viewtopic ... 47#p327047
Effect > Mosquito-Killer4: ...Mosquitoes to kill?: 8 > OK.
We expect the tool to make common USB whine vanish, but there are some versions of whine that don't perfectly respond. Listen carefully and if Mosquito_Killer4 fails or doesn't work enough, UNDO and post a help message on the Audacity Forum with a sample of the work.
http://forum.audacityteam.org/viewtopic ... 49&t=72887
I don't know of any easy, foolproof way to permanently fix a USB microphone once you have the whine sound. The most likely fix is change the computer. You can do it by not using a USB microphone. You can use a very high quality analog microphone plugged into a stable USB interface.
— PERMANENT or IMPOSSIBLE NOISE:
There are no tools to remove noises that constantly change. If jets overhead, traffic noises, dogs barking and the TV next door are included in your show, they are now your permanent performance partners. Read the work again in a quieter room. Gating is very difficult to use and generally doesn't help.
— COMBO PACK:
Nobody said you can't have more than one noise. The ACX AudioBook noise test can be rough to pass with a home recording system. If you just can't get there with the above tools, or you can't get your voice to sound right, post to the Audacity Forum with a sound sample and send a clean, raw clip. Mention the three-digit Audacity number.
Raw, please. We can't remove effects from a clip and posting your correction errors doesn't tell us anything.
dottedllama
Post by dottedllama » Wed Aug 02, 2017 6:52 pm
When I run through the steps you've laid out I notice that nothing seems to happen (no progress bar, change in wave forms etc) when I select RMS Normalize from my effects - and my ACX Check values show my RMS is in the 40s but everything else is passing.
What silly thing have I overlooked?
Diver4242
Post by Diver4242 » Thu Aug 03, 2017 9:56 am
dottedllama, are you sure you have selected the entire track you are working with first? Click in that area to the left where it says "Mono, 44100Hz, 32-bit float" and the track should be selected. The report you display shows about an 18 minute selection was measured, so it looks like you did. Other than that, I'm not sure why RMS wouldn't change anything. That's usually the one that produces the most obvious change in the waveforms in my track, as it makes everything louder.
Post by kozikowski » Thu Aug 03, 2017 10:21 am
RMS Normalize requires Audacity 2.1.3 or later.
http://www.audacityteam.org/download/windows/
We went around the barn several times recently when, like you, the reader had the tools fail and nobody could figure out why.
dottedllama
Post by dottedllama » Thu Aug 03, 2017 4:50 pm
Ah you see? I told you it was something ridiculous. Off to upgrade my version of Audacity....
Thanks Koz - as always you help keep me from leaving my head in my bum for too long!
Diver4242
Post by Diver4242 » Fri Sep 29, 2017 1:19 pm
Edited the original post, I had the files from book 3 up and they are pushing back on book two. So links and acx check screen shot reflect book two now. Thanks
I did my last audiobook with the sage advice and awesome help from here. So I was all like "yeah I got this" because it came out really well and sailed right through ACX checking and into the store for sale.
Now I did books 2 & 3 in the series and submitted them and ACX said there's a noise floor issue (how dare they). I did everything the same, same environment as last time, same gear, etc. I wonder if I missed a setting or maybe wasn't close enough to the mic? I'll post links to the raw WAV and resulting MP3 after I did the recommended EQ, RMS Normalize, and Limiter effects, and the resulting ACX Check result. To be fair, I do hear a low hiss. I'll try Noise Reduction of the Beast and the recommendations around NR but wanted to see if anyone could tell me what I did wrong this time around so I don't repeat it.
But why are they pushing back if my file says it passes acx check? This is just one chapter but they said it's all of them (all have similar numbers, all pass).
Thanks for all of the excellent help here!
Raw WAV: https://drive.google.com/file/d/0Bx52wr ... sp=sharing
Processed MP3: https://drive.google.com/file/d/0Bx52wr ... sp=sharing
Post by kozikowski » Fri Sep 29, 2017 3:44 pm
Did they give you a reason? They almost always give you a narrative of why it failed. Just telling someone their dB noise value didn't pass isn't useful.
A note here, ACX-Check isn't published by ACX. It's a tool designed by flynwill and company to "simulate" the ACX Robot. The Robot gets your work before a human sees it with the idea if you fail that, they don't have to go any further. I'm really interested in their fail post.
It's most unusual to pass ACX Check and still fail submission.
Post by steve » Fri Sep 29, 2017 4:10 pm
Diver4242 wrote:But why are they pushing back if my file says it passes acx check?
The ACX Check plug-in is intended as a "guide", not a "gold standard". It is a relatively simple tool. The noise floor measurement makes lots of assumptions and so does not always give accurate measurements. I've run some tests on the ACX Plug-in, and found that the noise floor measurement can sometimes be a long way off. More important than any noise floor measurement is what it sounds like.
Post by kozikowski » Fri Sep 29, 2017 4:32 pm
Which way and why?
I know the plugin needs a continuous half-second of room tone to measure noise. If the performer doesn't leave a half-second, the tool will guess at it.
Also, that Low Rolloff thing is a big deal. Can't leave that out.
