Rectifying a signal
Krischu
Rectifying a signal
Post by Krischu » Fri Jun 09, 2017 12:55 pm
Audacity 2.1.0
I have an audio signal of which I would like to retrieve just the amplitude in a kind as if I would rectify the signal to a half wave and then send this to a low pass filter. I'm just interested in the peak amplitude envelope.
How can I achieve this?
Christoph
Trebor
Re: Rectifying a signal
Post by Trebor » Fri Jun 09, 2017 2:27 pm
Krischu wrote:... I would rectify the signal to a half wave and then send this to a low pass filter ...
There's a rectify plugin for Audacity here ... viewtopic.php?f=42&t=64587
(It does full & half-wave rectification)
