Overdubbing
CJ3B
Overdubbing
Post by CJ3B » Wed Jun 07, 2017 12:18 am
What I have been doing is recording a guitar vocal track, and then on a new track, adding harmony. The problem is the 2nd track re-records the first track, so I get distortion. Has anybody experienced this?
Thank you,
Chris in VT
Trebor
Re: Overdubbing
Post by Trebor » Wed Jun 07, 2017 2:10 am
CJ3B wrote:What I have been doing is recording a guitar vocal track, and then on a new track, adding harmony. The problem is the 2nd track re-records the first track, so I get distortion.
Sounds like Audacity is recording the output of the computer, as well as the live guitar.
Try disabling "stereo mix" (or equivalent) in Windows Sound.
Once you've fixed that, the next problem you'll encounter is latency ...
http://manual.audacityteam.org/man/tuto ... bbing.html
Last edited by Gale Andrews on Wed Jun 07, 2017 12:28 pm, edited 2 times in total.
Reason: use offiical Audacity help link
CJ3B
Re: Overdubbing
Post by CJ3B » Wed Jun 07, 2017 11:47 pm
Oops! OS is Windows 10.
Re: Overdubbing
Post by Gale Andrews » Thu Jun 08, 2017 11:48 am
CJ3B wrote:Oops! OS is Windows 10.
Thanks for confirming but it is in your profile underneath your name.
Is the problem fixed? If not please tell us make and model number of the mic and how it connects to the computer.
CJ3B
Re: Overdubbing
Post by CJ3B » Thu Jun 08, 2017 10:12 pm
Hi Gale,
The problem is fixed - I simply moved the input and output to the front audio jacks of my computer. Not sure why it worked but I am very happy it did. Thank you for your help.
I don't detect any latency when overdubbing - should I run the test anyway?
Chris
