i saved my project as aup. then closed out of audacity but i tried to open it back up cause i wanted to change something and this error pops up? i dont know if its cause i put [ ] in the title of the project or if its something else. i already tried changing the name of the file and it didnt help, Any suggestions? i realllllly want this song back
Error: Reference to invalid character number at line 5
tavonjackson
Reason: placed image inline so that it fits Forum layout
- Quality Assurance
Re: Error: Reference to invalid character number at line 5
tavonjackson
my bad i didnt know you could post it. Heres the file im talking about
- Attachments
- Vacay prod. by TM.aup
- the AUP file
- (33.6 KiB) Downloaded 52 times
- Quality Assurance
Thanks. Try the attached. I removed �� (SMILING FACE WITH SUNGLASSES) and the other Unicode characters or emoji in the metadata. Audacity doesn't support these on Windows at present so you will have to do without them.tavonjackson wrote:my bad i didnt know you could post it. Heres the file im talking about
- Attachments
- (33.56 KiB) Downloaded 51 times
tavonjackson
youre a life saver! howd you access the metadata? just incase this issue comes up againGale Andrews wrote:Thanks. Try the attached. I removed �� (SMILING FACE WITH SUNGLASSES) and the other Unicode characters or emoji in the metadata. Audacity doesn't support these on Windows at present so you will have to do without them.tavonjackson wrote:my bad i didnt know you could post it. Heres the file im talking about
- Quality Assurance
I opened the AUP file in Notepad++, making sure that View > Word Wrap was off so I was looking at the line number indicated in the error. The metadata entries start withtavonjackson wrote:howd you access the metadata? just incase this issue comes up again
Code: Select all
<tag name="Gale
