hello everybody,
i upgraded to w7 from xp and since, audacity won't work.
the stereo mixer is correctly set and when i want to record with audacity i have a flat line and nothing helps.
when i switch to microphone, it records normally.
i have the adequate realtek driver and the sound works fine
thanks
no recording
- Quality Assurance
Re: no recording
Stereo Mix may require updating your sound device drivers, if it works at all. Try recording with Windows WASAPI (loopback) instead: http://manual.audacityteam.org/man/tuto ... ndows.html.
