AUP File Won't Open
Achtung74
AUP File Won't Open
Post by Achtung74 » Wed May 24, 2017 6:38 pm
I just recorded a segment for my podcast but when I go to open the aup file I get a message saying this is an audacity project file and that I need to use the File/Open command in audacity to open...this is exactly what I am trying to do!
The aup file has data in it and audacity is opening other aup files I have.
Any suggestions... this is a big file that I can't afford to lose! Thanks!
Re: AUP File Won't Open
Post by steve » Thu May 25, 2017 11:12 am
My guess is that the AUP file is damaged / corrupted. This can happen if the computer shuts down while the project is still being written to disk.
If you attach the AUP file to your reply, we can take a look to see if it is damaged / corrupted. See here for how to attach a file to your reply: viewtopic.php?f=49&t=64936
Achtung74
Post by Achtung74 » Thu May 25, 2017 1:48 pm
Thanks so much for the quick response. Files is attached...
DMR_The Return_Pt 2.aup
(108.07 KiB) Downloaded 48 times
Achtung74
Post by Achtung74 » Thu May 25, 2017 2:02 pm
Side note -- it is saved as an iTunes files (although still aup) because I was fooling around trying to get it to work and when I tried to open the file with itunes it was converted and I couldn't see how to change it back.
Post by Gale Andrews » Thu May 25, 2017 2:04 pm
Although the file is 100 kB it only contains NULL values. It is corrupted beyond use. Be sure not to shut down the computer or close the lid before the project is saved.
If you have a backup WAV file of the project, use that instead.
If you have no backup, then as long as it is the raw recording and you never edited it, you can recover the recording using this procedure: http://manual.audacityteam.org/man/reco ... ually.html.
Achtung74 wrote:Thanks so much for the quick response. Files is attached...
Post by steve » Thu May 25, 2017 2:06 pm
Unfortunately the file is corrupt.
If you open it in NotePad it will probably appear completely empty, though as can be seen from the file size that is not actually true. The file is full of "NULL" characters.
If the project was an unedited recording, then there is a (slim) chance that it may be possible to recover some or all of the data. See here for information about manual recovery: http://manual.audacityteam.org/man/reco ... ually.html
Post by Gale Andrews » Thu May 25, 2017 2:07 pm
Achtung74 wrote:Side note -- it is saved as an iTunes files (although still aup) because I was fooling around trying to get it to work and when I tried to open the file with itunes it was converted and I couldn't see how to change it back.
Only Audacity can open AUP files. You should never attempt to "convert" the file in other software.
Post by steve » Thu May 25, 2017 2:08 pm
Only Audacity can open Audacity projects.
To create a normal audio file, use "Export" (see: http://manual.audacityteam.org/man/auda ... jects.html)
Post by steve » Thu May 25, 2017 2:10 pm
Oops - simultaneous postings.
