Downloading a fresh copy of "hyperexp.ny" has solved the problem. For some reason my 2010 copy was slightly different ...steve wrote:@Trebor ... try installing http://wiki.audacityteam.org/wiki/Nyqui ... s#Hyperexp
want to hear a voice too low in a recorded conversation
Re: want to hear a voice too low in a recorded conversation
Do you still have your 2010 (non-working) version? If you do, could you PM it to me - I'd be interested to see why it doesn't work.
2010 version (attached) looks identical to the 2017 version I just downloaded,steve wrote:Do you still have your 2010 (non-working) version? If you do, could you PM it to me - I'd be interested to see why it doesn't work.
but they have different MD5 checksums ...
An invisible character somewhere ?
- Attachments
- hyperexp (2010).ny
- (865 Bytes) Downloaded 11 times
Not invisible, but easy to not seeTrebor wrote:An invisible character somewhere ?
Code: Select all
;type effectIt should be:
Code: Select all
;type process9/10 questions are answered in the FREQUENTLY ASKED QUESTIONS (FAQ)
