want to hear a voice too low in a recorded conversation
Hello Everybody,
I use Audacity 2.1.0, Windows 7 X64 SP1
I record my phone calls with an application called Call Recorder on an Android smartphone. Unfortunately several calls have problems: I hear my voice fine but the voice of my interlocutor is very very low.
So I decided to convert a file in mp3 and open it in Audacity. My goal is to increase the volume of the other person so I can hear her.
I attach a picture of the file in audacity. You can notice on the Track Window places where the wave is high(when I talk) and where it is very low (whe she talks).
Can someone advise me things I could do to even the volume of the entire conversation or a tip to at least largely increase the volume when she talks even if it induces a little saturation.
Thanks in advance
PS: excuse me for my spelling, I'm french.
Thanks in advance
Reason: placed image inline so that it fits Forum layout
Re: want to hear a voice too low in a recorded conversation
There's an experimental "Nyquist plug-in" here that may help: viewtopic.php?p=194179#p194179
Instructions for installing Nyquist plug-ins are here: http://manual.audacityteam.org/man/effe ... st_effects
Thank you very much for the answer and the time Steve. Really apreciated
I installed the plug-in and tried it on my mp3 with the settings advised: "Gain reaction speed" of around 0.5 seconds and the telephone setting .
But i still cannot hear the other voices, th voice is very very low.
Has anyone another solution?
Thanks in advance.
Thanks in advance.
- Quality Assurance
HyperExpand, (attached), then apply (soft) limiter with make-up gain.dallor wrote:... i still cannot hear the other voices, th voice is very very low.
- Attachments
- HyperExpand.ny
- (957 Bytes) Downloaded 20 times
- Soft Limit -10dB (You may have to apply this twice).png (10.57 KiB) Viewed 455 times
Very badly named (it actually does upward compression based on the RMS level), but works pretty well.Trebor wrote:HyperExpand
It seems to be essentially the same as this (slightly later?) version on the Audacity wiki: http://wiki.audacityteam.org/wiki/Nyqui ... s#Hyperexp
For some reason Steven Jones's original Hyperexp plugin would not even appear in the effect menu of Audacity 2.1.3steve wrote:... It seems to be essentially the same as this (slightly later?) version on the Audacity wiki: http://wiki.audacityteam.org/wiki/Nyqui ... s#Hyperexp
Maybe it's too old ? (2004) . I hacked at it until it worked to make HyperExpand.ny
Really?Trebor wrote:For some reason Steven Jones's original Hyperexp plugin would not even appear in the effect menu of Audacity 2.1.3
I wonder why that is.
I see quite a lot of "peculiarities" in the coding style of the original. What's your best guess as to what the problem is?
I can certainly update the version on the wiki, but it would be useful to know what the problem is with the current wiki version.
- Quality Assurance
On Windows 10 in 2.2.0-alpha, http://wiki.audacityteam.org/wiki/Nyqui ... s#Hyperexp appears in the Effect Menu for me.
steve wrote:Really?Trebor wrote:For some reason Steven Jones's original Hyperexp plugin would not even appear in the effect menu of Audacity 2.1.3You mean the version on the wiki?
Thanks Gale.Gale Andrews wrote:On Windows 10 in 2.2.0-alpha, http://wiki.audacityteam.org/wiki/Nyqui ... s#Hyperexp appears in the Effect Menu for me.
@Trebor, there can be weird things happen if a different version has been previously installed. Could you try temporarily moving the files, audacity.cfg, pluginregistry.cfg and pluginsettings.cfg out of the way, then launch Audacity (now as a "clean" installation) and try installing http://wiki.audacityteam.org/wiki/Nyqui ... s#Hyperexp
