Using bluetooth headphones
globetrotter1610
Post by globetrotter1610 » Wed May 10, 2017 2:14 am
I'm running Windows 10 and Audicty 2.1.3.
I'm using bluetooth headphones (Avantree Audtion Pro). Normally, everything works just fine. Now, the sound keeps "swapping" between the headphones and the computer. I have removed the headphones several times, and re-paired them. Nothing seems to be working to resolve the issue. All drivers appear to be up-to-date.
Any ideas?
Thanks!
Re: Using bluetooth headphones
Post by kozikowski » Wed May 10, 2017 3:26 am
What are you doing? Why did you buy the headphones? Are you talking on Skype? Recording Games?
Post by Gale Andrews » Wed May 10, 2017 1:52 pm
How long is it since you cold booted the computer? Windows button, Power button, hold SHIFT and click on "Shut down".
globetrotter1610
Post by globetrotter1610 » Wed May 10, 2017 9:00 pm
Thanks, Koz and Gale,
I use the headphones for "on the road" audio editing (not gaming, music, etc.).
I've tried removing the headphones from the device (Surface Pro 4) and then re-pairing them.
I'll try the cold re-boot.
UPDATE: For most of the day today, everything was working fine. Then, about 15 minutes ago, when I started the audio, it went to the headphones for about one second, and then shifted to the device. I powered down the headphones, then powered them up again. Same thing: one second over the phones, then shift to the device.
Thanks,
Bill
