Filter the same sounds of two audio files
For Musicians to Share Their Music, Tips, Tricks and Reviews.
WhoPlays
Post by WhoPlays » Tue May 09, 2017 3:35 pm
Hey guys,
I'm new to this forum and I am not sure if this is the correct subforum. But I hope it is.
Anyway, I have two audiofiles: Both are songs, both with the same vocals, but with different beats. The vocals are EXACTLY the same: Same time, speed, pitch, you get what I mean. It's just that they use different beats.
Now I'm wondering, is there a way to filter out only the sounds of the two audio files that are the same? So that I end up with (almost) only the vocals?
Looking forward to helpful replies!
Thank you!
-WhoPlays
Re: Filter the same sounds of two audio files
Post by steve » Tue May 09, 2017 3:43 pm
Previously I would have said "no, that won't work", but given some relatively new developments, I have an idea that 'may' work to some extent. To enable us to test, could you post about 5 or 6 seconds of both songs, with the same vocal in each. Export the samples in WAV format. Short WAV files may be attached directly to forum posts. See here for instructions: viewtopic.php?f=49&t=72887
WhoPlays
Post by WhoPlays » Tue May 09, 2017 4:32 pm
Of course!
By the way, the song is "Love Letters" by Watsky!
Watsky1.wav
(1.67 MiB) Downloaded 43 times
Watsky2.wav
(1.67 MiB) Downloaded 45 times
Post by steve » Tue May 09, 2017 5:02 pm
This is a mix of the two tracks after applying "vocal isolation" with this effect: http://manual.audacityteam.org/man/voca ... ation.html
mix.wav
(394.5 KiB) Downloaded 50 times
