Export Problem
alexauda
Export Problem
Post by alexauda » Mon May 08, 2017 5:48 pm
Hello,
I have a problem when I export the tracks: when I record a sound (principal track) and I want to add others with like panoramics, everything is OK, it sounds good so I export it. But when I listend to the result, it's very different and there's no panoramics. I'm not an expert so maybe it's a simple problem but...
Thanks
Re: Export Problem
Post by steve » Mon May 08, 2017 6:01 pm
I don't know what you mean by the word "panoramics".
Re: Export Problem
Post by kozikowski » Mon May 08, 2017 6:51 pm
If you mean stereo effects, is the exported show in stereo? Does it have two blue waves and are they different? Did you use File > Export Audio or File > Export Selected Audio?
