File size doubles after limiting
fwrunner2017
Operating System: Windows 7
Post by fwrunner2017 » Sun May 07, 2017 4:42 pm
Hi;
I am working with .wav (32-bit float) files in Audacity. I noticed that after I apply hard limiting, then save the file again in same format, the file size (Windows 7) just about doubles. Is this normal in order to keep the file lossless?
Thanks
Fw
Re: File size doubles after limiting
Post by steve » Sun May 07, 2017 5:40 pm
fwrunner2017 wrote:then save the file again in same format
What format?
fwrunner2017
Post by fwrunner2017 » Mon May 08, 2017 1:38 am
What format?
the wav 32-bit float format.
Post by steve » Mon May 08, 2017 8:34 am
32-bit float WAV is an unusual format. Are you sure that your original files are 32-bit float?
Audacity converts most file types to 32-bit float on import, which is great while editing / processing, but rather OTT for the final export (and may not play in some applications). I'd recommend exporting as 16-bit WAV unless you have a compelling reason not to.
fwrunner2017
Post by fwrunner2017 » Mon May 08, 2017 3:31 pm
steve wrote:32-bit float WAV is an unusual format. Are you sure that your original files are 32-bit float?
No, the files are 16 bit as ripped from the CD's. I used 32 bit float only because I wasn't thinking. I had been working with mp3 files, then decided to re-rip my cd's so I would have the original uncompressed file to work with. I guess I went a bit overboard going from mp3 to 32 bit. The 16 bit windows pcm is fine for everything I am doing.
FW
