USB Whine FIltering (Yeti Curse)
Trebor
Re: USB Whine FIltering (Yeti Curse)
Post by Trebor » Fri May 12, 2017 2:23 am
kozikowski wrote:ATTACHMENTS Mosquito-Killer4.ny (363 Bytes)
I just tried Mosquito-Killer4 in Audacity 2.1.3 in Windows Vista : it works as advertised, & menu entry is correct ...
Mosquito-Killer4 plugin in Audacity 2-1-3 in Windows Vista.png (93.67 KiB) Viewed 1234 times
Post by kozikowski » Fri May 12, 2017 2:31 am
OK, that I was not expecting. I know from cat that v3 and v4 appear close cousins of each other aside from the desired changes. I may have hosed my Audacity with one of the bogus install attempts.
Post by kozikowski » Fri May 12, 2017 4:23 am
Not dealt with the damaged install yet, but I know one failure. Make sure you got ~/Library and not /Library.
Both directories have Application Support and they both have audacity and they both have Plug-ins.
Post by kozikowski » Fri May 12, 2017 5:11 pm
Curiouser and Curiouser (for the moment I quite forgot how to speak good English).
So just to do it, I gracefully removed both Mosquito3 and Mosquito4 from ~/Library.
Screen Shot 2017-05-12 at 09.46.17.png (38.47 KiB) Viewed 1213 times
Audacity thinks they are "Disabled" rather than removed.
Screen Shot 2017-05-12 at 09.45.12.png (94 KiB) Viewed 1213 times
It does that on an older machine, too.
Would this be an accidental, undesirable feature or activity, experienced by multiple people on many different machines?
Post by Gale Andrews » Fri May 12, 2017 5:58 pm
kozikowski wrote: gracefully removed both Mosquito3 and Mosquito4 from ~/Library.
It's an enhancement request or bug depending on your point of view. Audacity does not know if you intended to delete them or intend to reinstall later. Certainly Plugin Manager should have a way to deregister an effect so it is not listed anywhere in Plugin Manager.
The Mosquito effects were automatically removed from the Effect Menu. We can do that for Nyquist plugins, but plugins in other formats would still be in the Effect Menu even though you deleted them, until you did an OK in Plug-in Manager. That's a bug, but it's not an easy fix to test for presence of an effect when opening the Effect Menu because of the time that can take for other plugin formats.
Post by kozikowski » Fri May 12, 2017 9:44 pm
Yes. I got that. That part does work.
I did restart the machine in the gaps there. I'm finding it really hard to avoid the "B" word. The listing in Enable Effects is Pure Fiction. It's also preventing me from repairing a damaged condition.
I need to go.
Post by kozikowski » Sat May 13, 2017 2:16 pm
In my opinion Mosquito-Killer4 and Man are complete. The only failure I know of is a MacBook Air who fell into an Audacity Program Unintended Feature.
Post by kozikowski » Sun May 14, 2017 2:07 am
Found it.
The original code has three periods after -Killer4.
Screen Shot 2017-05-13 at 18.42.22.png (11.02 KiB) Viewed 1188 times
The bad code has a single horizontal ellipsis (2026h) after -Killer4.
Screen Shot 2017-05-13 at 18.43.18.png (10.98 KiB) Viewed 1188 times
This time I watched it happen. This is Mac Text Edit trying to "help me."
I do kozco.com in Text Edit. I'm amazed I don't get stuck with this more often. Maybe I'm going to take the recommendation and use an actual html editor.
That still doesn't excuse needing to go into the system files with a sickle to fix Audacity.....
