Error: reference to invalid character number at line 6
Hey, I'm having an issue that I haven't exactly had before.
After saving a project for this one song I can't seem to reopen it without getting this stupid "invalid character error"
I saved multiple of the projects and all three are unopenable with that same problem.
My project folders and .aup files are completely intact, same name and everything.
I have Windows 7 Audacity 2.10 (After having had this problem I upgraded to 2.13 to see if I can open but to no avail)
Let me know what I can do to save my project. Thank you!
Re: Error: reference to invalid character number at line 6
Attach the problem .aup file and we can take a look.
See here for how to attach a file to your post: viewtopic.php?f=49&t=64936
Here you go, here are the 3-4 .aup files with this issue.
- Attachments
- swervv.aup
- (33.66 KiB) Downloaded 135 times
2nd one
- Attachments
- swerv 2.aup
- (33.66 KiB) Downloaded 73 times
I can tell you in the first one, line 6 appears to be a full-on, Purchase/Subscribe multi-linked commercial. Do you have a Mystery User on your machine with you? When was the last time you did a stiff virus scan?
Are you trying to post a forbidden commercial on the Audacity forum?
Line 5: (normal)
<tag name="ARTIST" value="Beats By Seismic"/>
Line 6: (not normal)
<tag name="description" value="�� Download | Purchase : http://bsta.rs/eca96 BUY 1 GET 3 FREE �� Website - http://www.BeatsBySeismic.net ➕ Subscribe! - http://bit.do/BeatsBySeismic �� Contact - [email protected] For untagged and/or any profitable use, please purchase a license: ▶️ http://bsta.rs/944da This beat is available as a free download for writing and auditioning purposes only. ______ playboi carti playboi carti type beat instrumental free playboi carti type beat lil yachty lil yachty type beat free lil yachty type beat lil yachy instrumental"/>
Line 5: (normal)
It looks to me like you are trying to use audio clips in your project contrary to the license terms of the copyright owner.Seaniboi wrote:After saving a project for this one song I can't seem to reopen it without getting this stupid "invalid character error"
The audio has embedded tags which include the following information:
Code: Select all
What exactly do you mean? The audio file I'm using is a simple instrumental from YouTube. It comes with tags so that if you want to profit or gain full rights to it you gotta buy it. Using it in my project and asking you guys for assistance shouldn't violate anything because I'm not
A. Profitting
B. Advertising(intentionally anyways)
But from what i can see I guess all that link garbage and crazy numbers shouldn't be in that line? How can I go about editing it without corrupting the files
A. Profitting
- Quality Assurance
It is not directly from YouTube, I believe. I think you have to go to the beats site and get the free download from there. That is the problem. The free download is tagged. Removing or modifying the tags on the free download, to make Audacity accept it in a project file, would make it "untagged", and would be a licence infraction.Seaniboi wrote:What exactly do you mean? The audio file I'm using is a simple instrumental from YouTube.
I think you will have to use another application to see if it can edit and resave the file without modifying the tags.
No, the tags its referring to are the producers little voice signature through out the song where it says "Seismic beats" and "Purchase your tracks today"
I got it straight from YouTube through anything2mp3 download. I can safely assure you nothing is being violated
- Quality Assurance
YouTube don't store MP3s, they store videos. The project you presented contains tags that can't be removed or modified without violating the licence.Seaniboi wrote:No, the tags its referring to are the producers little voice signature through out the song where it says "Seismic beats" and "Purchase your tracks today" I got it straight from YouTube through anything2mp3 download. I can safely assure you nothing is being violated
You will need to use an application that does not modify the tags.
