Win 7 sp1
Imported wav file
Audacity:
Audio Host = mme
Speakers(Realtek Hi def) does match my hardware
“Software playthrough” checked
ASIO not yet installed
Tested Realtek Hi def speakers in Win 7 control panel “sound” window – audible test sound is generated
Audacity playback meter displays 46-48 db output in both channels
Audacity Log: “FFmpeg libraries loaded successfully.”
Audacity Device Info:
Default playback device number: 3
Device ID: 3
Device name: Speakers (Realtek High Definiti
Host name: MME
Recording channels: 0
Playback channels: 2
Latency’s ...
Thank you for your help !
Compile Audacity 2.1.3 seems ok, but no playback sound
DennisTheNewbee
- Operating System: Windows 7
Re: Compile Audacity 2.1.3 seems ok, but no playback sound
That's a very low level. Try generating a tone (Generate menu > Tone) with the default 440 Hz 0.8 amplitude.DennisTheNewbee wrote:Audacity playback meter displays 46-48 db output in both channels
DennisTheNewbee
Fantastic Thank you!
