Dear members,
Hi, I was wondering whether any knows how to use Audacity to make sound effects that censor explicit words. It is very hard to describe but it is a common technique used on radio edits and I've always wanted to know how to do it.
I would prefer not to use silence and I don' t think the 'reverse' effect is always the best option.
I have attached a short sample of a song which uses the effect I am talking about.
Many thanks,
carryoutkyle
How to censor words using sound effects
carryoutkyle
- Attachments
- Censor Sample.mp3
- (59.21 KiB) Downloaded 539 times
- Quality Assurance
Re: How to censor words using sound effects
I can't hear any word obliteration in that sample, but that is not my kind of music. What are the words and where is the obliterated word amongst that?
You could keep it simple and beep a word out with Generate > Tone... . The tone does not have to be loud.
You can do that using "sliding time-scale / pitch shift" ...carryoutkyle wrote: It is very hard to describe but it is a common technique used on radio edits and I've always wanted to know how to do it.
ATTACHMENTS Censor Sample.mp3 (59.21 KiB) Downloaded 4 times
But you'll have to repeat (Ctrl+R) the effect 2 or 3 times though.
Ideally you should only apply this effect to the vocal track alone, not the music, but you probably won't have the seperate tracks, (unlike the producers of the radio-edit ).
The attached plugin produces a similar effect : it's like "scratching" vinyl records, which can be used to censor words .
The effect only works on audio less than 2 seconds duration, (when the sample rate is @44100Hz).
- Attachments
- Wikki-Warp.ny
- (625 Bytes) Downloaded 887 times
carryoutkyle
Thank you very much for your help everyone!
