Hissing noise in PSB-7 Spirit Box Audio
caseyparnell
Hello I'm trying to figure out how to remove the Hissing noise on my PSB-7 Spirit Box recording audio. I use noise removal to remove all of the White noise but seem to can't get rid of the hissing noise. Can someone please help? Would appreciate it.
Re: Hissing noise in PSB-7 Spirit Box Audio
Your question does not appear to make sense. White noise sounds like hissing.
- Quality Assurance
This is the same question as before about recording/isolating non-existent spirit voices: https://www.amazon.co.uk/P-SB7-Spirit-B ... B00545JSNG.
As suggested before, you will need to post a few seconds of raw, unchanged recording as a WAV or AIFF file if you want help, so we can understand the problem better. Please see here for how to attach files: http://forum.audacityteam.org/viewtopic ... 49&t=64936.
caseyparnell
Ok I uploaded a 55 sec Audio file from my PSB-7 Spirit Box. I did Noise Removal 3 Times. I sent a picture of my settings. There is still Hissing here and there. I cant figure out how to remove the hissing noises. How ever after the noise reduction has been done 3 times Listen closely at 44 seconds. Theres a voice that says Melissa. I don't know if the hissing noise is covering up responses or not. I just would like to know how to remove the hissing noise. For those who would like to help use the settings I got for Noise Removal 3 times. Any help on getting rid of the hissing noises would be appreciated.
- Attachments
- Z0000110.MP3
- (1.27 MiB) Downloaded 51 times
- IMG_0246.JPG (28.73 KiB) Viewed 1236 times
To apply Noise Reduction multiple times, you need to make a new "noise profile" for each pass.
I can hear a voice-like sound, but to me it sounds like it's saying "where ya vest today <squeak>"caseyparnell wrote:Listen closely at 44 seconds. Theres a voice that says Melissa.
Noise-reduction will generate processing-artifacts, some of which can sound like speech.caseyparnell wrote:... I did Noise Removal 3 Times.
The sample that caseyparnell posted is prior to noise reduction, and there is clearly a voice-like sound around 44 seconds. My best guess of where that voice-like sound comes from is that it is a fleeting snippet of a radio broadcast.Trebor wrote:Noise-reduction will generate processing-artifacts, some of which can sound like speech.
caseyparnell
Any idea in how to remove the Hissing noise though?
- Quality Assurance
You have Sensitivity at almost zero. Zero turns the Noise Reduction effect off, so you have almost turned the effect off. You should increase Sensitivity at least a little.caseyparnell wrote:Any idea in how to remove the Hissing noise though?
See http://manual.audacityteam.org/man/noise_reduction.html.
caseyparnell
I'll give that a shot. Thank you.
