I've recently downloaded a song, and I really enjoy this song's instrumental. Though, the artist has not published any instrumental version, and as he is not really famous, nobody has made one.
I've managed though to get the vocals of the singer, without the instrumental with it.
So I've got the full track (instrumental + vocals) and the vocals only. What I want is the instrumental. My question is, is there a way of "removing a track from another" ?
I've tried "Vocal Remover" first, which gave me a totally ruined instrumental with still a echo of vocals behind.
Then, I looked up a bit on the Internet and found out a method that implied separating the stereo tracks, applying the "Invert" effect, then setting each track to "Mono" instead of "Right canal" and "Left canal" respectively. That gave me the save result as "Vocal Remover".
So what now ? Does someone have an idea ?
Thanks,
Fox
PS : I'm quite a noob when it comes to installing additional things in Audacity, so you'd be really kind if you could explain everything there is to explain
