OS: Windows Vista SP2
Version: All builds this year up to 2.2.0 10-apr-17. Does not happen in 2.1.3-alpha-27-jul-16. Can't say exactly when it started - guess I liked that July rev too much.
I always download the zip file, copy portable settings into the unzipped folder on the desktop and run Audacity from there so I can compare revs when I have to.
No special procedure needed to reproduce this, just display History after loading a project and applying some effects, editing, etc. Attached is an example of what I mean.
- DickN
Size column entries in History are on the wrong lines
- Attachments
- Screenshot of History showing Size entries on the wrong lines. The region selected for equalization was 4m 35s+70f.
- history.PNG (50.86 KiB) Viewed 222 times
Re: Size column entries in History are on the wrong lines
I agree it is confusing, but it is by design (and I was out voted).
The "size" numbers represent the amount of disk space that will be recovered when using "discard levels", not the amount of space that was used when doing the listed command (so not the amount of space that will be recovered by "undoing").
- Quality Assurance
And the Manual does say this: http://manual.audacityteam.org/man/undo ... ml#history. In the previous way of doing this, the size values for items would change after discard, which in its way was just as confusing.
The dialogue needs a rework really.
waxcylinder
+1Gale Andrews wrote:The dialogue needs a rework really.
Peter
