Problems with high dpi monitors
Please state:
Post by steve » Sun Apr 09, 2017 9:37 pm
There's a whole bunch of problems, and they may be platform specific. Here are some of them:
On a modestly high dpi monitor, the help screen dialog is tiny and cannot be resized.
L/R labels in meters:
Project rate not visible:
Re: Problems with high dpi monitors
Post by Gale Andrews » Sun Apr 09, 2017 11:02 pm
James committed https://github.com/audacity/audacity/commit/53e6d - did it help the L / R?
Is your monitor standalone or part of a laptop? What is the resolution and what DPI is set?
I probably can't help with this because I don't have a high res monitor. The highest res I have is an old iMac. I think Team should plan to fund some equipment, not just for me.
Post by steve » Sun Apr 09, 2017 11:18 pm
https://github.com/audacity/audacity/commit/82a77788
Default settings:
Post by steve » Mon Apr 10, 2017 2:44 pm
Gale Andrews wrote:Is your monitor standalone or part of a laptop? What is the resolution and what DPI is set?
It's the laptop monitor.
1920 x 1080 (so not that high dpi, but high enough that I need to increase the font size in "Appearance" settings to be able to read things).
Gale Andrews wrote:If any images can't be scaled by the preferred OS method then they will blur, I assume.
Screenshots on the same machine. The new "classic" theme buttons look like a "posterize" effect has been applied.
Audacity 2.1.3
Audacity 2.2.0-alpha-Apr 10 2017 "Classic" theme
