problems recording audio streams using Dell
Spiritmale
Post by Spiritmale » Sun Apr 12, 2009 8:52 pm
Hi. I have noticed that Audacity doesnt record well with Dell computers using sound cards by Sigmatel. Even tho I have selected the input as Stereo Mix, I am trying to record a stream from youtube and it only gives me the option to record in Mono.
I was wondering if anyone else has experienced this issue and has found a way to overcome it.
I did find a toolbar from Ask.com that records audio streams in stereo, so i am using that in the meantime.
Thanks,
GL
Gene45
Re: problems recording audio streams using Dell
Post by Gene45 » Mon Apr 13, 2009 1:42 am
This thread is also on a Dell machine. If that helps.
http://audacityteam.org/forum/viewtopic.php?f=12&t=8383
