2.1.2
Re: 2.1.2
Without extensive changes to the code this is not possible.robirion wrote:How do I make the mouse cursor larger?
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
waxcylinder
Re: 2.1.2
Actually when you move the cursor into the track areas it changes toi correspond to the tool that is currently selcted in the Tools Toolbar.robirion wrote: ...When the cursor is moved into the track area it shrinks. (
See: http://manual.audacityteam.org/man/tools_toolbar.html
Reason: Fixed link
Reason: Fixed link
