Resume playback in a project [SOLVED]
temoin.de.yehovah
Post by temoin.de.yehovah » Sat Apr 01, 2017 12:35 pm
How to make the mark to continue to listen to a sound exactly or has arrived after close audacity ?
Reason: more specific topic title
Re: How to make the mark to continue to listen to a sound...
Post by steve » Sat Apr 01, 2017 3:11 pm
Sorry but I can't understand what you are asking.
Try to describe what you are doing and what the problem is.
Post by Gale Andrews » Sun Apr 02, 2017 1:26 pm
You can add a label then save a project.
Audacity plays from the editing cursor in saved projects. Audacity remembers the position of the editing cursor in saved projects, but not if you already saved changes to the project and then move the cursor.
temoin.de.yehovah
Re: Resume playback in a project [SOLVED]
Post by temoin.de.yehovah » Sun Apr 02, 2017 3:46 pm
ah ok big thanks please close topic
Gale Andrews wrote:You can add a label then save a project.
