Where to send Audacity_dbgrpt
DickN
Post by DickN » Fri Mar 31, 2017 6:11 pm
OS: Windows Vista SP2
Rev: 2.1.3-alpha-25-Feb-17
I created a new label track and tried to copy an existing label into it so I could export a piece of the audio and let Audacity create the filename. I kept getting a message "can't create autosave" or something like that (although I had 40+ GB of free disk), and when I tried to move the focus between label tracks the label tracks changed positions vertically on the screen.
Audacity generated a dump and I added a note. But where should I send it? It's attached here.
Audacity_dbgrpt-4512-20170325T012502 (2).zip
Debug report generated 3/25/17 by Audacity 2.1.5-alpha-Feb-25 2017.
(67.49 KiB) Downloaded 11 times
Re: Where to send Audacity_dbgrpt
Post by Gale Andrews » Sat Apr 01, 2017 11:46 am
DickN wrote:OS: Windows Vista SP2
Bug reports are accepted here or at the feedback address (http://www.audacityteam.org/contact/#feedback).
Given you wrote here, you don't need to write to [email protected] as well.
However, if you want to test in alpha builds, please always test in the absolute latest build, not in one that is five weeks old: http://gaclrecords.org.uk/win-nightly/. I don't seem to have a problem in the latest build with pasting a label into a new label track.
